Ok, 20 reads of my first post and no comments - I have to do better than that. My problem is in the following. I wrote a script for tyrosine radical EPR spectra simulation, in which three principal g values, hyperfine splittings, and Euler angles are functions of just two input variables. The script works fine and I can see differences in the simulated spectra when I change these two input numbers (and the differences are quite right). However, what I cannot do at this stage is to fit the simulated spectrum to the experimental one using esfit. I setup my two input variables as Sys parameters, for example,
Sys0.theta = 56;
Vary.theta = 2;
Sys0.ro = 38;
Vary.ro = 3;
but when I run esfit asking to vary just these two parameters it all comes back to the starting point, as a matter of fact it doesn't move away from the starting point, which is probably understandable - the script reads the zero values every cycle.
So my question is whether there is a way around this and I could use esfit to vary two variables on which the Hamiltonian parameters are defined (without explicitly varying the latter) or should I write a different fitting routine?
I will appreciate any feedback,
Dima Svistunenko
an esfit problem - more details
Re: an esfit problem - more detals
Dima, please post a minimal working script that shows all the inputs you give to
esfit
, and also post the data if possible. Then somebody might be able to help.Re: an esfit problem - more details
OK, I will make another attempt to describe the code.
Here is the bottom of the script:
As you can see, many of these Sys. parameters (all that are not numbers) are functions. They are functions of one, two or three variables - roC1, theta and cAm. I can vary manually these three, separately or together; a reasonable simulation comes up for these values, for example:
Now, I would like to run a fit when only these three numbers are varied. To make the things simpler, I want to vary only cAm first, starting from a random value of, say, 0.1 and to cover a range of +/- 1 around it. So, a successful fit should be giving me something close to cAm = -0.5
So, cAm is embedded in Sys.HStrain = [deltaHx deltaHy deltaHz];
so that deltaHx deltaHy deltaHz are functions of roC1 (a constant in my fitting attempts) and cAm (to be varied during the fit)
To vary just cAm, I set
at the top of the script, that is before the Sys0.cAm is used in calculation of [deltaHx deltaHy deltaHz]:
I am not surprised that when running esfit:
it does not move way from Sys0.cAm since in the second cycle it reads again Sys0.cAm but I don’t know how to fix it.
I guess I am basically asking if a Sys.X variable can be set as a function of another Sys.Y variable and an esfit routine executed when only Sys.Y is varied.
Stefan, I sent an email to you at stst on 20 August with a full script and experimental spectrum. If you received it, I would greatly appreciate your comments and I would perfectly understand if whatever I am asking is going to take more efforts and time than you are prepared to invest.
Dima Svistunenko
% Spin system and Optional paramters:ZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZ
Sys.g = [gx gy gz];
Sys.Nucs = '1H,1H,1H,1H,1H,1H';
Sys.A = [Ab1Para Ab1Perp Ab1Perp;
Ab2Para Ab2Perp Ab2Perp;
25.9 8.1 20.5;
25.9 8.1 20.5;
7.5 5.0 1.5;
7.5 5.0 1.5
Sys.AFrame = [euler11 euler12 euler13;
euler21 euler22 euler23;
-23.0 0 0;
23.0 0 0;
-40 0 0;
40 0 0
]*pi/180;
Opt.Method='perturb';
% Spin system and Optional paramters end:ZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZ
[BestSys,BestSpc] = esfit('pepper',a4,Sys0,Vary,Exp,Opt);
roC1= 0.38; % spin density on C1, might be varied between 0.35 and 0.42
theta= 56; % in degrees; should be between -90 and +90 degrees
cAm = -0.5; % positive or negative correction value to be added to the line widths, typically within a range -1.2 - +1.2 Gauss
Sys0.cAm = 0.01;
Vary.cAm = 1;
deltaHb=[widthonK*a6]; % delta H BASIC, a column
deltaH=[deltaHb+[Am; Am; Am]+[Sys0.cAm; Sys0.cAm; Sys0.cAm]]; % delta H, a column of full width components
Dima Svistunenko
In this situation, use a custom simulation function, as described here.
% load data here
Sys.g = [gx gy gz];
Exp.mwFreq = 9.5;
Exp.Range = [300 400]
Sys.roC1 = 0.38;
Sys.theta = deg2rad(56);
Sys.cAm = -0.5;
Vary.rhoc1 = 0.1;
Vary.theta = deg2rad(30);
Vary.cAm = 0.2;
[BestSys,BestSpc] = esfit(@mysimfun,a4,Sys0,Vary,Exp,Opt);
function spc = mysimfun(Sys,Exp,Opt)
roC1 = Sys.r0C1;
cAm = Sys.cAm;
theta = Sys.theta;
% calculate deltaHx, deltaHy, deltaHz from these parameters
% calculate all A and Euler angles
25.9 8.1 20.5;
25.9 8.1 20.5;
7.5 5.0 1.5;
7.5 5.0 1.5
-23.0 0 0;
23.0 0 0;
-40 0 0;
40 0 0
]*pi/180;
spc = pepper(Sys,Exp,Opt);
Thank you very much, Stefan, it works now, hurray!!
It took me some time though to realise I have to make a separate file to be called in by the main script. Anyway, it works now and I will investigate how to optimise the fit process - how it depends on the starting point, on the range to vary within and on the number of variables (total of three) to vary at a time, and if the order of the variables in the script (when greater than one) matters.
Thanks a lot , I am very greatful,
Dima
Dima
