Hi all,
I am using esfit to fit 3pESEEM time domain data and for this I have just to load time domain experimental data and set the EPR parameters required for 3pESEEM saffron function and use esfit straightforward. I would like to know if it's possible to use esfit to fit frequency domain 3pESEEM data.
Regards
esfit function
Re: esfit function
One way to do this is to write a custom fitting function, which calls
saffron
and then returns the frequency-domain spectrum. Then, call esfit
with this function and supply your experimental spectrum.Re: esfit function
Hi Stefan,
Many thanks for your reply. I will give try!!
Regards
Regards
