Longtime lurker, first-time poster. I'm having an issue with relative ratios of double integral values between multiple samples as measured by EasySpin versus Xenon or OriginLabs. My assumption is that I am doing something wrong in EasySpin/MatLab, though I cannot discern what that is.
I have recorded CW X-band EPR spectra of validated solutions of TEMPOL, Cu ICP and Mn standards. I have measured the double integral (e.g. integral of the absorption spectrum) using Xenon, EasySpin and OriginLabs. The relative ratio of double integral when measured by EasySpin is different the value from Xenon or OriginLabs by almost a factor of 5! My goal is to spin count using the CuICP as a standard, hence, this difference makes it impossible to use the EasySpin values. I'm wondering if the technique I use to do the double integral in EasySpin/MatLab is the source of these errors. Searching the forum, however, suggests that I am on the right track (see "Area under EPR transition" for 2016 for example - viewtopic.php?f=3&t=307).
My scripts, sample data files and a PDF explaining the issues in more details are attached.
I thank everyone who spends some time looking at this.
Justin
Double integral values in EasySpin vs. Xenon
- forEasySpinForum.zip
- (1.28 MiB) Downloaded 498 times
Re: Double integral values in EasySpin vs. Xenon
I haven't looked at your scripts, but here's how to do a double integration. Don't forget to include the field increment.
Make sure to do all the processing, such as baseline correction and smoothing, prior to this.
Sys.g = 2;
Sys.lw = 1;
Exp.Range = [337 342];
Exp.nPoints = 1000;
[B,spc] = pepper(Sys,Exp);
plot(B,spc)
dB = mean(diff(B)); % field increment
spcIntegral = cumsum(spc)*dB; % integrated spectrum
doubleIntegral = sum(spcIntegral)*dB % double integral
- EasySpin Guru
I see three potential sources for the differences.
The first, you're using
The second do origin and xenon basline correct line you're doing in matlab?
And lastly
cumsum
and sum
, you forgot to weight the integral with the field step size (look at Stefan's example). But if you're consistent, field range and number of points always the same, it doesn't really matter.The second do origin and xenon basline correct line you're doing in matlab?
And lastly
cumsum
uses the midpoint rule to perform the integral and is generally accurate. But you could improve the accuracy by using cumtrapz
and trapz
which use the trapezoid rule for the integral. Difference in the integral method between matlab/xenon/origin could explain some divergence.Re: Double integral values in EasySpin vs. Xenon
Thanks for the suggestions. The issue was that I did not weight the integral with the field step size, which is important because I did NOT collect the data with consistent field range and number of points. I have included my 'final' script below for posterity.
Justin
Justin
% Template script for determination of Double Integral
% CuICP standard
% JTD 9/9/20
clear, clf
% update with filename
[b,s,param]=eprload('01_14_Cu_optscan_T25K_38dB.DTA');
%plot(b/10,s,'k');
% 1st-order baseline correct using basecorr
s_bc=basecorr(s,1,1);
%plot(b/10,s_bc,'k');
% Integral
db=mean(diff(b));
s_bcI=cumsum(s_bc)*db;
%plot(b/10,s_bcI,'k');
% Polynomial baseline correction
% from EasySpin forum Matt Krzyaniak
tail = b/10 < 260 | b/10 > 350 & b/10 < 400;
[p,Es,mu]=polyfit(b(tail)/10,s_bcI(tail),4);
baseline=polyval(p,b/10,Es,mu);
s_bcIbc=s_bcI-baseline;
%plot(b/10,s_bcIbc,'k',b/10,s_bcI,'b',b/10,baseline,'r');
% Integral of absorptive spectrum (aka double integral)
DI=sum(s_bcIbc)*db;
% check by taking numerical derivative of baseline corrected
% absorptive spectrum
s_bcIbc_deriv=diff(s_bcIbc)/db;
b_deriv=b(1:length(s_bcIbc_deriv));
plot(b/10,s_bc,'k',b_deriv/10,s_bcIbc_deriv,'r');
