New esfit does not recognize FitOpt.Baseline argument
Using FitOpt.Baseline = 0, 1, 2, 3, or 4 is not recognized by the GUI window.
The esfit window always starts from "Baseline none" and the baseline type needs to be manually defined.
This is in version 6.0.0-dev.51
Re: New esfit does not recognize FitOpt.Baseline argument
This could be a capitalization issue. Try FitOpt.BaseLine instead of FitOpt.Baseline.
Yes, that was the issue!
I believe a correction should be made at the esfit documentation page downloaded with the latest version.
Thanks Stefan.
We will fix the documentation - thanks for pointing this out!
In a (probably) related issue, FitOpt.PrintLevel seems to have no effect on the output's verbosity when esfit is invoked without the fitting GUI. Even setting to 0 produces the full output.
I have tried capitalization permutations (printLevel, Printlevel, printlevel) without luck.
In version 6, this has been renamed to Verbosity, to be more consistent with other EasySpin functions.
