Error in EPR load
Error in EPR load
I recently installed Matlab R2015b. When I tried to load a bruker file the following message came up.
I am not sure what bufSize is. Can anyone help please?
>> [B59d,spc59d] = eprload('kk759d_wide');
Error using textscan
'BufSize' is no longer required and has been
removed.
Error in eprload
Error in eprload
Error in eprload
removed.
Error in eprload
Error in eprload
Error in eprload
Re: Error in EPR load
Check whether you have the latest version of EasySpin. This used to be a bug, but was fixed in 5.0.8.
That was it!
Thank you.
Thank you.
I have Matlab 2015b and EasySpin 5.0.22, error for multiple files of Xenon and Xepr origin is:
'BufSize' is no longer required and has been removed.
Error in eprload
Error in eprload
Error in plot_ENDORxy (line 10)
[b,a,par] = eprload('AUTOSAVE0000.DTA');
This started spontaneously after some weeks/months with the Matlab EasySpin combo above. I'm using a pre-textscan eprload for now.
Error in eprload
Error in eprload
This should not appear anymore in 5.0.22 with R2015b. Here is the corresponding code from
Please post a file so we can test this (again).
eprload
MatlabVersion = sscanf(version,'%f',1);
if MatlabVersion<8.6 % prior to R2015b
warning('off','MATLAB:textscan:BufSizeDeprecation');
allLines = textscan(fh,'%s','whitespace','','delimiter','\n','bufsize',500000); %#ok<BUFSIZE>
else
allLines = textscan(fh,'%s','whitespace','','delimiter','\n');
>> version
ans =
8.6.0.267246 (R2015b)
>> easyspininfo
Release: 5.0.22 (2016-05-17)
Expiry date: 30-Jun-2017
Folder: [ ... ]
MATLAB version: 8.6.0.267246 (R2015b)
Platform: Microsoft Windows [Version 6.1.7601]
mex-files: mexw64, ok
System date: 16-Jul-2016 21:39:01
Temp dir: [ ... ]
ans =
>> easyspininfo
Folder: [ ... ]
Temp dir: [ ... ]
Please post DTA and DSC files that generate this error, so we can look into it.
Sorry I missed the following error messages that appeared previously. The file attachment appears like it might work this time.
The extension dsc is not allowed. The extension des is not allowed. The extension txt is not allowed. rename extension to DSC
The extension dta is not allowed. The extension dat is not allowed. rename the extension to DTA
Thanks. I cannot reproduce this problem. The file loads cleanly with R2015b and 5.0.22 on my Win10 computer. Can you check whether the correct functions are being called? Use
which eprload -all
which textscan -all
That's it! Sorry I thought I had checked that previously by paring the path down to just EasySpin, but apparently not. Many thanks. -Will
...\Documents\MATLAB\UserCommunity\BrittLab\eprload.p
