Easyspin source code
Charles
Post by Charles »
I heard rumours that the source code of Easyspin will be published soon. Is this true? If so, at which time is this planned?
Thanks for your help
Charles
Re: Easyspin source code
There is no explicit time frame for this. We anticipate 2017.
mifrye
Post by mifrye »
Are there any updates on this? I'm trying to develop a Python script to mimic eprload to use on a Raspberry Pi, but have had trouble decoding the .SPC files.
As I know, SPC file is a simple sequence or 4-byte floating point values. All other data are in the PAR file which is ASCII text.
The PAR/SPC format changed quite a bit over time, depending whether you look at ESP data, WinEPR data, etc.
Here are a few snippets that should help. Little vs. big endian can make a difference:
% For DOS ByteOrder is ieee-le, in all other cases ieee-be
if isfield(Parameters,'DOS')
  Endian = 'ieee-le';
  FileType = 'w';
else
  Endian = 'ieee-be';
The data could be complex or 2D:
% Analyse data type flags stored in JSS.
if isfield(Parameters,'JSS')
  Flags = sscanf(Parameters.JSS,'%f');
  isComplex = bitget(Flags,5);
  TwoD = bitget(Flags,13);
The file type determines the number type in SPC:
% FileType: flag for specific file format
% w   Windows machines, WinEPR
% c   ESP machines, cw EPR data
% p   ESP machines, pulse EPR data
% Set number format
switch FileType
  case 'c', NumberFormat = 'int32';
  case 'w', NumberFormat = 'float'; % WinEPR/Simfonia: single float
  case 'p', NumberFormat = 'int32'; % old: 'float'
pegli
Post by pegli »
Are there any new plans to make the source code of Easyspin available as open source software?
Is it planed to port Easyspin to freely available frameworks like Python/Numpy ?
We are working on making the EasySpin source code openly accessible.
Regarding Python/Numpy, there are currently no plans. It would a significant effort, and we unfortunately don't have the bandwidth to do that.
