Some proposals for futher versions
I woul like to propose some additional features which which could be implemented in new version of EasySpin.
1. Manual definition of A,B,C coefficients in fast-motion regime in addition to calculation from A and g matrices and correlation time.
2. Definition of "subrange of interest" from whole spectrum range for esfit function. For example, full spectrum have a range [300 400], but esfit use only [350 400] part ignoring [300 350] one. Of course, several "subranges of interest" should be better.
Re: Some proposals for futher versions
Thanks for the suggestions!
1. We created an issue for this.
2. This is already on our list.
Thanks. I think, one more feature would be added to the interactive mode of esfit. Now esfit uses predefined "center point" values, there are no way to change it without restarting of the fitting process. It should be better if these values may be replaced by ones from "best fit" set.
I see two posiible ways for it. Two button "best->center" and "reset" may be used. Another way to make an additional item in "Startpoint" list like "center from selected parameter set".
