Several "CrystalOrientation" + "Output = 'separate'" Bug?
trukhan
Post by trukhan »
Something strange with the example "solidstate\cumnt2.m" in EasySpin 5.2.3
The spectra obtained are completely different than those were before.
If this code
Exp.CrystalOrientation = [0 0 0; 0 pi/2 0];
Opt.Output = 'separate';
[B,spec] = pepper(Sys,Exp,Opt);
spec1 = spec(1,:);
spec2 = spec(2,:);
replace with
Exp.CrystalOrientation = [0 0 0];
[B,spec1] = pepper(Sys,Exp);
Exp.CrystalOrientation = [0 pi/2 0];
[B,spec2] = pepper(Sys,Exp);
then the spectra are the same as in previous versions of EasySpin 5.1.9 and older (taking into account the correction viewtopic.php?f=3&t=387).
Re: Several "CrystalOrientation" + "Output = 'separate'" Bug
This is an unintended consequence of some internal changes in 5.2. Prior to 5.2, for a simulation with multiple isotopologues and multiple orientations, Opt.Output = 'separate' would return spectra separately for each orientation, now it returns it separately for each isotopologue. We will try to revert this to the old behavior. Thanks for reporting this problem!
This is now fixed in 5.2.4.
