Convolution of spectrum with custom line shape
I need help to understand how to make the spectrum with custom line shape (without convspec function). I suppose that IFFT images of stick spectrum and shape array of the same size should be multiplied and FFT should be applied back. Also, the zeroes should be added at both ends of the arrays to awoid artifacts appearing. But this procedure gives unexpected results. Here the example:
clear;
Exp.Range=[340 350];
Exp.mwFreq=9.65;
Exp.nPoints=4096;
Sys.g=gfree;
Sys.lw=[0 0.5];
Range=[340 350];
pos=342;
npoints=4096;
[x,y]=makespec(Range,npoints,pos);
y1=garlic(Sys,Exp);
z=zeros(1,npoints/2);
y=[z y z];
y1=[z y1 z];
y=ifft(y);
y1=ifft(y1);
y2=y.*y1;
y2=fft(y2);
y2=y2(1+0.5*npoints:1.5*npoints);
plot(x,real(y2));
What I do wrong?
