SALT problem in ver. 5.2.21
RuslanZaripov
Post by RuslanZaripov »
Dear Stefan,
I installed the last stable version of easyspin 5.2.21 (since my working version 5.2.9 ends soon) and I have a problem. When simulating the ENDOR of single crystal spectra (even endorsimple.m), the salt function always gives out the powder spectrum, regardless of the value of Exp.CrystalOrientation. When installing the previous version 5.2.9 everything works fine, although the development version 6.0-alpha2 has the same problem as 5.2.21. What could be the reason?
Re: SALT problem in ver. 5.2.21
Please post a short self-contained script that reproduces the problem.
RuslanZaripov
Dear Stefan,
The script is:
% 1H ENDOR of a powder
clear, clf
% Spin system
Sys.g = 2;
Sys.Nucs = '1H';
Sys.A_ = [1 3];
Sys.lwEndor = 0.3;
% Experimental parameters
Exp.Field = 350.1;
Exp.CrystalOrientation = [0; 0; 0]*pi/180;
% frequency range is determined automatically
% Simulation
salt(Sys,Exp);
Into the standart endorsimple.m body I just insert Exp.CrystalOrientation and nothing changes.
This is a bug - thanks for reporting! It is now fixed in version 5.2.22, which you can download from the website.
RuslanZaripov
Thank you very much.
The salt function works correctly in ver. 5.2.22.
Regards,
Ruslan
