EPR load DAT file
Macgomes
EPR load DAT file
Post by Macgomes »
Hello everyone,,
I am quite new to the EasySpin world and have been able to simulate some data but have yet to be able to actually load and plot an actual data file. Currently, I am trying to load a high-field pulsed EPR that is saved as a DAT file.
I enter the following xvideos.onl/ xnxx.onl/ chaturbate.onl/ command: [B, spc] = eprload('C:\Pathtofile\Filename.dat')
and get this response: Error using eprload, The file is not an Adani spectrometer file.
So I tried to change the file extension to DSC and DTA and then I get a response that the file does not exist. I have checked my path multiple times and went as far as to copy and paste it directly from the properties window... It still does not load. I am running on MATLAB R2016a with EasySpin 5.0.22, with a Windows computer.
Not sure what I am doing wrong, I will appreciate any help I can get!
Thanks..
Re: EPR load DAT file
What fileformat is your DAT file? What spectrometer is this from? Is it a home-built one? In that case, you will need to write your own load function.
