2-component analysis system!!
gabrielthomass
Post by gabrielthomass »
Hello to all !
I am working in 2-component EPR simulations using the chili, but I was wonderng if there is any possible way to calculate from the simulated spectra the percentage of each population. As I am a new user of Easyspin for multicomponent systems any suggestion will be usefull for me.
Thank you in advance.
Best regards
evgeniaYoujizz Pornhub Tubegalore
Re: 2-component analysis system!!
It is not clear what you are asking for. Are you simulating multi-component spectra, or are you fitting experimental multi-component spectra. In the latter case, if you want to fit the weights, you can use esfit and include Sys.weight among the parameters to fit. Sys.weight holds the weight per component.
